LabVIEW APIs Discussions
moving a wire
I've scripted a RCF plugin to insert a node in a wire, drop a String Constant near it, right-justify its text, wire the two together and clean-up the wire.  The result looks like this:
I'd like to be able to move the vertical portion of that wire one pixel to the right (OCD).  Changing the wire's position property doesn't have an effect, and the joints in the wire are not writable.  Can you tell me how to do this?
Jim
Jim
(6,608 Views)
As far as I know (I have not checked in LV 2009 & 2010) there is no way to move a wire. If you want to  do this, you have to delete it and recreate it using wire joint.
Philippe
(5,098 Views)
Accepted by jcarmody
Have you tried selecting the wire (using MakeSelection method of TopLvlDiag) and then moving the selection.
(5,098 Views)
Jim
(5,098 Views)
Ah, I misunderstood what you were trying to do. I did not realized you were trying to move the entire wire (I though you were trying to move only one "wire segment" in the wire).
(5,098 Views)
