12-03-2019 06:05 AM
thx for the example. Do you also have a version, that works with IPv6?
12-03-2019 06:51 AM
I have not tested IPv6 yet, but there is a good chance, that it works with IPv6 as well. Maybe it is worth to try it: Just specify the unicast and the multicast addresses as IPv6.
05-02-2020 07:48 AM
I have executed code for SOME/IP protocol among Server (C++) and Client (C++) with the help of described method at "https://github.com/GENIVI/capicxx-someip-tools/wiki/CommonAPI-C---SomeIP-in-10-minutes" .
Now as my next experiment, I need to connect another client (HTML5/JS) to this Server (C++) via SOME/IP. I am unable to find the HTML supportive/binding files. I have below query for that
1) Where I can find the "code generator tool" which can generate the binding code for HTML client.
2) If "code generator"is not there, Is there any another way for create binding files.
3) As I see the in this Labview example, there are SOME/IP supporting files in the project. How these are created.
Please help me in this. Thanks in advance.
Kuldeep
10-06-2020 06:12 AM
I'm trying to run Client_Subscribe.vi but something is wrong.
Error Out:
Code: 1097
Source: Call Library Function Node in Client_Subscribe.vi
How can I solve it?
Thank you!
10-06-2020 09:14 AM
Looking up the error code, it appears an exception occurred within the external code called (see article). Have you been able to run the Client_EventAndField.vi example successfully, or does the same error occur there as well? If you run into issues there, be sure that you have carefully examined the README and have followed the steps there.
10-07-2020 05:00 AM
Solved problem!
I made a mistake with DLLs because I have 64-bit version Windows and 32-bit version LabView.
Now, all works fine.
Thank you!
10-21-2020 05:58 AM - edited 10-21-2020 06:12 AM
I'm running Client_Event_Serialized_Payload but traffic is in loopback adapter instead of Ethernet Adapter (server is offering services there).
What can I do?
Thanks in advance.
10-26-2020 05:46 PM
Just to confirm, does your C:\etc\vsomeip.json file specify a unicast address that matches the IP address of the interface you are trying to use (as documented in CONFIGURATION_FILE.txt)? After changing this value, you may need to restart your system.
Out of curiosity, how many Ethernet adapters are in your system?
10-27-2020 03:44 AM
There are two Ethernet adapters, which is in all devices. The IP address and netmask for the Ethernet adapter in use is set manually and written in vsomeip.json.
Anyway, I have disabled the ethernet adapter that I don't use and it doesn't work either. It only sends [find] requests through loopback.
03-17-2023 02:23 PM
Hello there, I'm working in a device that uses SomeIP as a server so I'm using in my PC the "Client" Vi's to communicate with the device.
I noticed using Wireshark when sending a service_request you can send the Major/Minor version, but when sending a request using the "Client_SendRequest.vi" the SomeIP Interface version in the header always remains as "0". So the question is:
The following is the process:
