LabVIEW Channel Wires
Adapt to element type
A few days ago I started to study through the Channels. I am looking at the "Channel Basics Lesson" project for first. I play with the examples, and discovering their behavior, so you might expect some more questions in this specific forum board from me later too 🙂
I took a part from Lesson 7, where we can fork a Stream Channel into to Streams using the Replicate node. If I change the Data type for the Write node, I can right click on it, and select "Adapt to data type". However, the Replicate.vi does not have this right click menu option. So we need to delete (and create again) or replace it to accept the incoming Stream channel wire. The Reader.vi can also adapt. Why the Replicate.vi does not have this menu option?
(5,960 Views)
Oops, an oversight on our part.  I submitted a bug report to get that fixed.
(5,947 Views)
