LabVIEW Channel Wires
Can Stream wires not be used in CD & Sim
When I try to write something is always says vi failed to compile.
(6,006 Views)
Hello  artokivila,
i also see this behaviour. I created an internal corrective action request to fix the behaviour or to document it. Queues are working to transfer the data.
best regards
Alexander
(5,981 Views)
The scripting behind CD & Sim has not been updated to properly deal with Channels, so while the diagram may look okay it will not compile properly.  Beyond the scripting issue, there is a more fundamental semantic issue: the Sim diagram is executing in virtual time while the rest of the diagram is executing in wall clock time.  Figuring out how to properly bridge from one to the other is a challenging problem, particularly in the presence of some of the more esoteric solvers.  Currently, this is an unstaffed issue, but if you have a compelling use case we would like to hear about it.
(5,939 Views)
