LabVIEW Communications System Design Suite
EEG signal transmission to LABVIEW using TWO XBEE
Hi everyone,
I have a single channel EEG amplifier and i'am working on EEG signal transmission from an arduino board to LABVIEW. is there any code for arduino and labview to make a good transmission with XBEE and display a good acquisition signal ??
(3,067 Views)
Hi meth12,
It looks like you've posted a similar question in a number of other forums. In particular, it looks like my colleague Mitchell provided an extensive list of resources regarding interfacing with your Audrino in LabVIEW here. I think it would be best to consolidate your communication in one post -- can you respond to Mitchell with more information on what specifically you are running into issues with the documentation he's provided you?
Sunayna R.
Applications Engineering
(2,987 Views)
