LabVIEW Communications System Design Suite
PAM RX implementation in labview
Hello.
I have a simple problem dealing with all the day. I really appreciate if you can help me out. Please see the attached picture.  I am trying to implement a PAM RX. I need to connect output of MT Generate PAM System Parameters  to input of MT Map Bits to PAM Symbols. But I dont know how to make the data compatible.
(4,426 Views)
I figured I need to use unbundle cluster by name. I can not find it in labview communication!!!!!!! It is in labview under cluster pallet but not in labview communication!!!
(4,405 Views)
Accepted by topic author Ferdoon
Hello Ferdoon,
In Comms and NXG, you use the Cluster properties node to unbundle by name:
I apologize fort the confusion.
Gerardo
(4,384 Views)
Thank you.
(4,379 Views)
