LabVIEW Communications System Design Suite
Graphs do not update after running VI
Hey there,
When I run my VI, the graphs on my panel won't update to the latest value. Instead they are showing no values. This happens only when I run the VI from the panel. When running the vi from the diagram, and switch to the panel afterwards, the graphs show up correctly with the latest data.
Does anybody have an idea how to solve this issue?
(3,842 Views)
Can you please post the VI?
Norbert
Norbert
Expert: Geometry
(3,820 Views)
After restarting my PC it started working now. I'm using LV Comms v2. I attached the VI, maybe it can help, but im not able to reproduce at the moment.
(3,817 Views)
Hi a_bert,
Can you post a zipped project? There a quite a few subVI's that are missing with only this VI.
Ben C.
RF Systems Engineer
(3,751 Views)
Accepted by a_bert
I was able to fix this issue by updating my graphics driver (same reason as for: http://forums.ni.com/t5/LabVIEW-Communications-System/LabView-won-t-open-Fixed-Point-Configurator-am... )
Thanks for your help anyway 🙂
(3,617 Views)
