LabVIEW Communications System Design Suite
How pass an constant array of gvi to constant array or stream of gmrd?
Hello
Good,
I write because I need pass a big constant array of  gvi (VI) to constant array or stream of gmrd (Multirate Diagram).
Basically,  I need  upload large arrays or stream and I don't write element by element.
thanks for your help
Leo
Message 1 of 8
(6,823 Views)
Is this on the host or FPGA?
Rahul B.
Message 2 of 8
(6,821 Views)
all FPGA
Regards
Leo
Message 3 of 8
(6,818 Views)
Check the Guided Help (Learn tab>>Getting Started>>FPGA>>Deploying Applications to an FPGA, it shows you how.
Basically, when you drop an MRD down its inputs are FIFO references. Note that because MRDs are their own clock domains, they exist outside a CDL loop and communicate via FIFOs for streaming data in and out.
Rahul B.
Message 4 of 8
(6,815 Views)
I find other solution
In Multirrate Diagram  put FPGA IP.
This is a VI diagram,
copy constant array  and asigned port for select data array and out data.
remenber, put correct type data
regards
Leo
Message 5 of 8
(6,804 Views)
Ahh, I misunderstood. I thought you were trying to determine how to pass data into MRD from your CDL. Yeah that makes sense, and there are some Stream to Array functions in MRD too!
Rahul B.
Message 6 of 8
(6,801 Views)
Do you mind attaching a screenshot of the soluition so we can see?
Thanks!!
Rahul B.
Message 7 of 8
(6,796 Views)
good day
I attached an example
thanks
Message 8 of 8
(6,682 Views)
