LabVIEW Communications System Design Suite
design rule problem
Hello
I write because I have a problem .
for you understand I attached an example of my problem
I'm work with big stream  and multirate diagram is big,  but  I broke this diagram in subdiagram of necesary recourse  it grows
my example stream it is from 4096 but that pass if I do of 65536, It'll full memory ram
I hope I have explained my problem
regards
Leo
(5,732 Views)
I'm sorry but I don't follow what you are doing exactly. I downloaded the project you attached but what should I be doing and what behavior should I be seeing?
(5,718 Views)
just hug and do nothing.
monitor server resources where it's opened
memory consumption begins to grow
Leo
(5,715 Views)
attached other example of my problem..
with only open design of  use means grow
do you undestand my problem?
Leo
(5,712 Views)
I see a memory growth on my computer as well. I'm not sure what is going on, I'll have to look into it.
(5,700 Views)
I understand that it must follow certain design rules for the compiler and / or interpreter to work properly.
I do not know these rules and my implementation have this problem.
(5,693 Views)
