LabVIEW Communications System Design Suite
How to index through a cluster?
I have a cluster which contains several 1D arrays with different lengths, and I want to iterate through them in a for-loop, such that I can process each array individually.
I found this `solution' for the standard LabVIEW, but I'm working in LabVIEW Comms 4.0 which is based on LabVIEW NXG, hence, that solution isn't possible.
Any help is appreciated 🙂
Best,
Ziad
Message 1 of 1
(2,950 Views)
