LabVIEW Communications System Design Suite
error in converting project from labview communication design suite 2.0 to 2.1
I succeed in convert process, but the converted new project reports many compile errors, the most errors are the same:
Error LTE DL Host Initialization.gvi The document contains an unrecognized property: LicenseFeatureNames from the plugin: LabVIEW Virtual Instrument. This can occur when loading a document that was last saved with a newer version of a plugin.
this error happens in each gvi in the converted project, and I do not have any idea to fix the error, Please help!!
I appreciate your help!!
(3,103 Views)
Hi )
Below you can find link to guide, which provides guidance on how to migrate existing LabVIEW Communications 2.0 applications to LabVIEW Communications 2.1 and 3.0, and common issues that can occur during the migration.
https://www.ni.com/en-us/support/documentation/supplemental/18/labview-communications-2-0-to-2-1-and...
Hope this will help you.
Meri
(2,776 Views)
