LabVIEW Communications System Design Suite
Initialize 1D array with prespecified values
Hi all,
I am pretty new to the comm suite, but I'm having a (probably rather simple) question about initializing an 1D array constant. Let's assume that I want to create an 1D array constant of size M and that I want to initialize it with certain prespecified values. Is there an easy/efficient way to do this? Initializing it one by one is rather cumbersome, especially for large M. Also, how can I initialize such a constant on an FPGA Traget?
I have seen that e.g. for multirate VIs it is possible to define a stream constant and initilize it with a .cvs file. Is there a similar possibility for initializing a 1D array constant?
Cheers,
steve0
(6,347 Views)
Accepted by topic author steve0
Hi Steve0,
I've found a quick and dirty workaround for this, as there is not a clear method to implement an arbitrarily large array constant. You can generate an array however you'd prefer, my example is seen below:
And then go to the Front Panel, right click on the indicator, and select "Capture Data". From there, that array will be available on your Data panel to drop as a constant to other VI's in that project. You can also do the same with a CSV file, by writing your CSV file to an indicator, and then capturing the data to use.
BeenCoughin
(6,319 Views)
steve0,
As BeenCoughlin mentioned, the best way to do this is to write a VI that reads your CSV file and populates an indicator. You can then convert that indicator to a constant, or use the capture mechanism to store that data in the data window (and then drop it as a constant).
In the next version we are planning to support importing the data from directly from a CSV file into the data window.
Gerardo
(6,301 Views)
Hey BeenCoughin and GerardoG,
thank you very very much for your suggestions! For the solution I took the suggestion to write an VI that reads a CSV/TXT file and poplutes an indictor. Then I use captue and drop it as a constant. It works allthough changing the values of the vector would still need a manual manipulation of the constant. The possibility of dirctly importing data from a CSV file into a data window thus would really come in quite handy. Do you know when the new version is planned to be released?
Cheers,
steve0
(6,281 Views)
Hello Steve,
I am sorry. We can't announce any information with regards to the release, but as soon as it goes live look for a post like this:
http://forums.ni.com/t5/LabVIEW-Communications-System/LabVIEW-Communications-1-1-is-LIVE/td-p/319358...
Thomas C.
FlexRIO Product Support Engineer
(6,256 Views)
