LabVIEW Communications System Design Suite
Is there anyone who developed LTE-LAA AFW for Labview Communication System Design Suite NXG 3.0 ?
I have had LAA AFW for Labview communication suite 2.0.
But code version of LAA AFW in Comm Suite 2.0 to NXG communication suite 3.0 was very hard,
and I could not accomplish that so far.
(3,706 Views)
But code version of LAA AFW in Comm Suite 2.0 to NXG communication system design suite 3.0 was very hard,
and I could not accomplish that so far. Thanks.
(3,709 Views)
Hi Jack15,
The recommended flow migrating Application Frameworks projects to the new version of LabVIEW Communications is to integrate custom IP into a new version of the relevant Application Framework.
Have you seen the migration guide for 2.0 -> 2.1/3.0 conversion? If not, it might help you work around some of the hurdles that you've encountered:
https://www.ni.com/en/support/documentation/supplemental/18/labview-communications-2-0-to-2-1-and-3-...
If you're still having difficulty after reviewing that document I would recommend reaching out to support at ni.com/support.
(3,611 Views)
Hello  Jack15
I am doing my research on LTE/WiFi coexistence and I have a questuon that how can I get the LTE-WiFi coexistence Application Example about the white paper mentioned above? Now, I only have the normal NI LTE Framework, which is not enough to support the experiments I expected.
Sorry to bother you, I appreciate your help!!
(3,476 Views)
