LabVIEW Communications System Design Suite
OFDM Example code, CFO Correction Block Error
Please suggest how to get the target block in attached picture.
Code: OFDM TX & RX
Hardware: USRP 2943
Error in: CFO Correction Dependency "Ramp Pattern by Samples".
I am running example OFDM tx & rx Code on USRP 2943 . In receiver VI , in CFO Correction dependencies one block "Ramp pattern by samples" is showing error " This method call node couldnot find its target. The target may have been moved renamed or deleted".
Please specify and locate how to get the asked target?
Thanks & Regards
Lucky
(4,551 Views)
Please I am encountering the same problem. Can someone help us?
(4,158 Views)
replace it with this library
http://www.ni.com/documentation/en/labview/4.0/analysis-node-ref/ramp-pattern-by-samples/
(3,775 Views)
