LabVIEW Communications System Design Suite
LTE application framework: Pulse to Strobe function
Hi. I'm working on LTE application framework to support my research. I have some difficulties in understand the function of Pulse to strobe U16 module (in DL TX/ LTE DL TX IQ Processing/ LTE index generator). I don't know what "strobe" tearm means, and what the module Pulse to strobe U16 is for!
Thank you for your help!
(4,840 Views)
Accepted by quyptit
Hi quyptit,
A strobe is often considered a signal that defines a sampling period for another signal.  All the Pulse to Strobe U16 function is doing is latching the pulse signal for a given number of pulse widths.
(4,810 Views)
Hi Luke, thank you for answering my question!
(4,799 Views)
