LabVIEW Communications System Design Suite
LabVIEW Communications System Design Suite with Windows 10 64-bit
I would like to know is there any way to run LabVIEW Communications System Design Suite on Windows 10 64-bit. As per the NI website it says it only supports Windows 7 64-bit. So is there any way to run it on Windows 10 64-bit.
Please guide.
Thanks in advance.
(6,230 Views)
Accepted by josephkirmani
Hi josephkirmani,
Currently LabVIEW Communications System Design Suite is not supported on Windows 10-64 bit. You may be able to get it to run on your machine, but sadly it is not officially supported outside of Windows 7-64 bit.
BeenCoughin
(6,217 Views)
Could you tell, how one can make it run on windows 10.
(4,082 Views)
