LabVIEW Communications System Design Suite
Not open Help! A problem of proxy
Dear,
I  have a problem.
when I set a block and I press "F1" . don't open online help.
Labview Communication 1.1.  to use system proxy?
How do you set a especific proxy?
regards
Leo
(10,533 Views)
Hi Leo,
Though you likely have found this online, here is the link to the help manual.
LabVIEW Communications System Design Suite 1.0 Manual
http://www.ni.com/documentation/en/labview-comms/1.0/manual/labview-comms-manual/
I am not immediately aware of the reason you are not able to use the F1 key. What operating system are you running on?
When you press 'F1', does anything happen?
Finch Train
(10,358 Views)
If you use a proxy to connect to the internet, Labview cannot connect to its server such as FPGA complie server and help server.
You can install "Proxifier" to route every packet from your PC through proxy port. It works for me.
(10,328 Views)
thanks
I use webnavigator, but if I do direct of LabVIEW Communications System Design Suite with F1, I could error of attached picture
regards
Leo
(10,313 Views)
Accepted by Leonardo_Castillo
Just try installing Proxifier (http://www.proxifier.com/), add your proxy server and add rules for it like the image below. But If you don't want to use one more application just to use help function, use web instead.
(10,304 Views)
thanks
regards
Leo
(10,280 Views)
