LabVIEW Communications System Design Suite
SOQPSK demod
Hello
I am trying to implement SOQPSK demodulator.
I want to know is it possible to convert QPSK or OQPSK to SOQPSK
by using the one which is available in LabVIEW and how ??
(4,570 Views)
I haven't worked with OQPSK, but it seems to me the easiest way is to convert from regular QPSK. I'm working from the information here:
http://www.ni.com/tutorial/5487/en/
It seems to me you could use the modulation toolkit to do this.
  1. Start with a QPSK waveform
  2. Take IQ data from QPSK (after symbol mapping) and upsample by a factor of 2
  3. split complex array into I and Q
  4. Delay Q array by one sample
I'm not familiar with SOQPSK, but maybe you could derive that from the OQPSK IQ data?
Edit: Looks like modulation toolkit actually includes some OPQSK examples: MT Offset QPSK Equalization.vi, MT Offset QPSK Mod-Demod.vi, and MT Offset QPSK Transceiver.vi.
Dale S.
RF Systems Engineer - NI
(4,545 Views)
Hello Sir
Thanks for your earnest response.
Sir is there any third order Butterwoth filter or just half sine filter or a average matched filter readily available in the toolkit
(4,534 Views)
Try browsing the VIs in this palette.
Dale S.
(4,526 Views)
