LabVIEW Communications System Design Suite
Set the random seed of the random number generator in Matlab Node
Dear all,
I need to use some random variables inside a Matlab node in Labview Commsuite. I generate them with the function randn(). Is it possible to set the seed of the random number generator such that the random numbers are repeatable?
(5,200 Views)
Accepted by steve0
Hi Steve,
You can use randn('seed', seed) to initialize the random number generator. The seed should have a positive integer value. For example, randn('seed', 3). Also, this seed is global within the entire application. This means if the function randn() is called in multiple MathScript nodes which could run in parallel, the random results are not guaranteed to be the same after you modify any part of your code. But you should still get the same results for repeated runs of the same code.
(5,132 Views)
Thank you very much, that was the solution!
By the way, interestingly enough randn() and rand() use different random seeds. So setting the seed for randn() does not control the seed of rand().
Cheers,
Steve
(5,127 Views)
