LabVIEW Communications System Design Suite
USRP RIO Dataclock configuration
Hi all,
This worked perfectly.
Sorry for the late feedback.
Message 11 of 12
(1,567 Views)
Hello Brooksprumo,
Can you please explain more about the nodes used in the required clock driven loop in the FPGA VI ?
What is the functionality of the four FPGA I/O write Nodes ?
Do they allow the FPGA to write samples coming from external signal sources through the 4 USRP ports ?
If it is correct, are the written signal samples downconverted to baseband automatically ?
What is the function of an FPGA I/O read node ?
Does it read values from the host ?
kindly,
Ali
Message 12 of 12
(991 Views)
