LabVIEW Communications System Design Suite
[USRP-RIO] Error -367000 in modified streaming example
we are using the following setup:
  • A USRP-RIO is connected via PCI card to a desktop PC (transmitter)
  • Another USRP-RIO is connected via PCI card to another desktop PC (receiver)
  • A modified version of the stock streaming example is used to transmit and receive.
  • The modifications are limited to waveform generation and display, i.e. 2 independent Tx channels and 2 independetnt Rx channels are employed
  • LVC version 1.0.0.50009
Turning the transmitter on and off, every once in a while, this message would occur after pressing the "STOP" button. Between the different runs, I have been actually only changing some settings in the GUI. The behaviour was not reproducible in a deterministic way.
By now, the problem does not occur anymore. Not sure what was the actual solution.
Nicola
(5,826 Views)
Hi Nikola,
since you do not know, which settings produced the issue, I can only guess what could have been the cause: The error usually indicates a trigger timeout. So if you use a trigger line but no trigger is received over a specified time, the error message is seen.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(5,809 Views)
