LabVIEW Communications System Design Suite
how to read a file that contains a matrix !!
Accepted by topic author emnajaoua
Hi Emnajaoua,
yes, it is possible. As i said before, you have to know the format of your file and then you can manipulate in in LabVIEW. In this case you have a 1D Array as a text file with three space elements as value delimiter. So I read the text string and format it into a 1D Array under consideration of the format. You can see the result in the attachement.
I hope this gives you a better understanding of how to handle data like this.
Message 11 of 12
(1,754 Views)
Hello ,
Thank you very much.I am new to labview communications design and I didn't know how to convert the data of input file.
Have a nice day.
Best Regards,
Emna Jaoua.
Message 12 of 12
(1,749 Views)
