LabVIEW Development Best Practices Discussions
Using NI 9467 GPS module
Well, it's been 2 years since you asked. I am hopeful that you got this part working (aquiring data and timestamping at 1ms intervals)  Did you find any examples, etc. to help since you didn't get a response here?
Message 31 of 33
(3,536 Views)
Hello JCC,
I know its been over a year, but if you happen to have a copy of this stored somewhere, I would greatly appreciate a copy to review
Message 32 of 33
(3,534 Views)
Hi Guys,
I am working on a project which uses NI 9467 GPS module and i am unfortunately new to this module. In the project, i also use SEL 2407 satellite synchronized clock in order to get time signals via an antenna. I send these signals over BNC cables to my NI 9467 GPS module. However, when i try to get these signals on LabVIEW using ''Synchronize to GPS-cRIO.vi'' which locates under ''FPGA timekeeper 1.1b0.zip'' file at ''https://forums.ni.com/t5/Sync-Labs/NI-TimeSync-FPGA-Timekeeper-Getting-Started/gpm-p/3543895'', i always observe an ''overcurrent'' situation on my antenna status and my GPS status is ''unable to get fix''. Therefore i always see the status LED on my NI-9467 module as solid yellow. Do you have any idea why this is happening?
Thanks in advance for your kindly replies.
Şamil Baycan Yalçın
Msc. Student/Mersin University
Message 33 of 33
(3,179 Views)
