LabVIEW Development Best Practices Discussions
help me please in my project
hello
this is pressure control calcul
I want to translate this code in LABVIEW
Note that PH2,PO2 a signal
pressure
Caclul de   |PH2-PH2|= ΔP
Si ΔP>ΔPs alors (ΔPs = 6 ou 13 ou 19 ou 34)
Si  PO2>PH2 alors   Po2 régulée = PO2 – ΔP
Sinon : PH2 régulée = PH2 – ΔP
Si ΔP<ΔPs alors (ΔPs = 6 ou 13 ou 19 ou 34)
Si PO2<PH2  Po2 régulée = PO2 – ΔP
Température :
Testimée (calculée) – Tréf(65C°) = ΔT
Si  ΔT > 0 alors T de refroidissement = ΔT
Sinon T de refroidissement = 0
and thanks
(6,016 Views)
Accepted by sofianesoft100
OK, so start by taking a look at case structures, and at the items on the Comparison palette.  Try something and then ask further questions at the point where you get stuck.
(4,947 Views)
Even better, ask your questions in the LabVIEW forum where these "help me" type support questions are usually asked and answered.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(4,947 Views)
thank you
(4,947 Views)
