LabVIEW Digest Programming Challenges
LabVIEW Digest Challenge 3
I wasn't eligible to participate, but I would have submitted a variant attribute based solution. 😄 Here's what I did a few weeks ago.
See if you understand the algorithm ...
Disclaimer: To save me time and effort, the LUT is based on BrotherTom's code above, so I am not sure if it is complete and I don't know which standard should have been used. This is just a code skeleton to show the general principle. Would be easy to expand if needed.  🙂 It currently returns a question mark if a pattern is not found in the LUT.
(EDIT: This is similar to the NXG version)
Message 11 of 17
(6,393 Views)
You can also use regular expressions to locate and match morse syntax:
I think you can combine the regex with the variant attribute table constant to create a very small VI.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 12 of 17
(6,367 Views)
I'm afraid that I d'on't have time to increase my knowledge in LabView to trial a CLAD exam 😞
If Charlotte want to design a new winner, I will be happy for him!!!
Message 13 of 17
(6,185 Views)
This is my solution.
HOB Consultores S.A.
Área de Investigación, Desarrollo e Innovación Tecnológica
Message 14 of 17
(5,790 Views)
Hi! Good Day. Can I request a copy of this winning vi solution? I am new to LabVIEW and I am wondering if I can use this as a basis for our class. Thank you.
Message 15 of 17
(5,306 Views)
Hi, here are the files 😉
Message 16 of 17
(5,288 Views)
Thank You very much!
Message 17 of 17
(5,249 Views)
