LabVIEW Embedded
ARM Module + LM3S8962 PWM problem
hello, if still not solve the problem check the attachment to a project is working very well controlling a servomotor
Message 11 of 13
(3,897 Views)
Message 12 of 13
(3,890 Views)
In this program you want to control the movements of a servomotor UP button: left position, right position DOWN, LEFT central position, stop SELECT program. The program consists of two routines, the first is responsible for the generation of messages on the screen of the card and the second PWM output signal at port, more https://decibel.ni.com/content/docs/DOC-35059
Message 13 of 13
(3,694 Views)
