LabVIEW Embedded
Automatic code running after reset
where and how do I have to locate my code to build an application that runs by itself after a reset?
Message 1 of 10
(10,638 Views)
I assume you are asking how to program the Flash of the Blackfin EZKIT. If so, read this KnowledgeBase article to learn how. [article no longer available]
Michael P
Message 2 of 10
(10,631 Views)
Thanks 🙂
Message 3 of 10
(10,624 Views)
Hello does somebody know the cause of this fault?
Have a look at the attached file.
Best Regards
Message 4 of 10
(10,620 Views)
You're missing an argument. I noted it in bold text below.
elfloader MyApplication.dxe -b flash -f hex -Width 16 -init "init_code_bf537_ez-kit_lite.dxe" -o MyApplication.ldr -si-revision 0.2 -proc ADSP-BF537
Michael P
Message 5 of 10
(10,617 Views)
I am sorry I printed it out and there was no proc 😞 on my sheet Thanks
Message 6 of 10
(10,610 Views)
Michael,
I have successfully flashed a labview demo to the EZ-Kit, but it takes a very long time to flash a 978k LDR file....like on the order of an hour....is that normal?
Larry
P.S. Here is my Flash dialog and the settings that I used...
Message 7 of 10
(10,402 Views)
How I can cancel the code inserted in the memory Flash ?
Message 8 of 10
(10,023 Views)
You can't "un-program" the flash and get what was there before. If you want to program the flash to code that it comes with, see the files in this directory: "VisualDSP 4.5\Blackfin\Examples\ADSP-BF537 EZ-Kit Lite\Power_On_Self_Test\".
Michael P
Message 9 of 10
(10,010 Views)
I want to make an other question .
I am working with LabVIEW 8.2 Embedded Module for ADI Blackfin Processors (BF537). I can implement on Blackfin BF537  the VI  "ICA" that is found in  the Advanced Signal Processing toolkit ?
Please, I waited for an answer because I am working to a search plan about the signals EEG .
Thanks .
Message 10 of 10
(10,008 Views)
