LabVIEW Embedded
Inline C Node on Blackfin Beta 2.0
I am using the Labview Embedded for Blackfin beta 2.0
I am trying to run the example for 7.1 where the processor uses an Inline C Node to detect its IP address.  Everytime I put down the node, the error message tells me that inline C is not supported for the current target.  The target is the BF537 EZ-Lite kit.  I thought the inline C node was supported?
(7,356 Views)
To add an Inline C Node to a VI, the VI must be opened in the context of an embedded target. Move your VI under a Blackfin target in the LabVIEW Project, then open it.
Michael P
(7,337 Views)
Can you  send to me an example VI   where I can execute with Incline C Node a filter  that was designed using the LabVIEW Digital Filter Design Toolkit ?
(7,173 Views)
Can you give me an C code of FastICA ?
(7,169 Views)
