LabVIEW Embedded
Blackfin ez-lite compile error on 537 FlagCallback example
I received the following message from the details on Compile error when I "Rebuild All" on the ADSP-537 FlagCallbackExample.
Sorry for the long message, but I don't know which part of it might be important.
Any thoughts?
Hummer 1
*** compiler output ***
C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application>"C:\Program Files\Analog Devices\VisualDSP 5.0\ccblkfn.exe" -O1 -Ov100 -c -proc ADSP-BF537 -threads -labview -implicit-pointers -I. @.\prjHeaders.lst -DCHeadless -D__vdk -D__USE_FFT_REL45__ -Wsuppress 0001,1661 "C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application\FlagCallback1.c" @.\prjOptions.lst
C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application>"C:\Program Files\Analog Devices\VisualDSP 5.0\ccblkfn.exe" -O1 -Ov100 -c -proc ADSP-BF537 -threads -labview -implicit-pointers -I. @.\prjHeaders.lst -DCHeadless -D__vdk -D__USE_FFT_REL45__ -Wsuppress 0001,1661 "C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application\FlagCallback2.c" @.\prjOptions.lst
C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application>"C:\Program Files\Analog Devices\VisualDSP 5.0\ccblkfn.exe" -O1 -Ov100 -c -proc ADSP-BF537 -threads -labview -implicit-pointers -I. @.\prjHeaders.lst -DCHeadless -D__vdk -D__USE_FFT_REL45__ -Wsuppress 0001,1661 "C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application\BF_Flag_Open.c" @.\prjOptions.lst
C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application>"C:\Program Files\Analog Devices\VisualDSP 5.0\ccblkfn.exe" -O1 -Ov100 -c -proc ADSP-BF537 -threads -labview -implicit-pointers -I. @.\prjHeaders.lst -DCHeadless -D__vdk -D__USE_FFT_REL45__ -Wsuppress 0001,1661 "C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application\BF_Flag_Install_Callback.c" @.\prjOptions.lst
C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application>"C:\Program Files\Analog Devices\VisualDSP 5.0\ccblkfn.exe" -O1 -Ov100 -c -proc ADSP-BF537 -threads -labview -implicit-pointers -I. @.\prjHeaders.lst -DCHeadless -D__vdk -D__USE_FFT_REL45__ -Wsuppress 0001,1661 "C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application\FlagWithCallback.c" @.\prjOptions.lst
At end of source: : internal error: Uncaught exception Assertion failed raised
          at ../../../libutil/cii/src/array.c:38 (in pass final_annotate
          during compilation of _FlagWithCallback_BlockDiagram). Please submit
          a bug report with this message, the command line used, type of
          machine and the output of the compiler when you add -ED -v to the
          command line. Please also send us the pre-processed file that is
          generated by the -ED option (the file generated is named
          <original_filename>.i)
1 catastrophic error detected in the compilation of "C:\Program Files\National Instruments\LabVIEW 2009\examples\lvemb\Blackfin\BF537\Flag with callback\BF537 FlagWithCallback\BF537\VDK_Application\FlagWithCallback.c".
Compilation aborted.
cc3089: fatal error: Compilation failed
*** linker output ***
(6,055 Views)
Hi Hummer1,
I will look into this error, but I have a couple questions.
1.) Does this happen when you choose to "Build" as well?
2.) Does this happen only with the FlagWithCallback example or with all examples?
Aaron P
http://www.ni.com/support
(6,030 Views)
