LabVIEW Embedded
Communicating with Blackfin
Also, I did try running a 527 example, but I get a different error.
Failed to locate VisualDSP++ files need to continue. Please make sure that VisualDSP++ is properly installed and configured in the target options dialog.
I am pretty sure it is installed OK because I have been using without trouble. I am not sure where the target options dialog is though to check.
I tried running the BF527 UI.VI.
Message 11 of 17
(3,969 Views)
And I did find the configure target, which seems to be configured correctly.
Message 12 of 17
(3,969 Views)
I have also tried working through the getting started tutorial and I receive the previous include error again once I get to the build Blackfin application part.
Message 13 of 17
(3,968 Views)
Hey,
1.  We need to make sure the VDSP is installed... it is possible you might have only installed the module.
2.  Even if it is installed, please re-install it.
3. Also, when you open the DF527 example, are you building a VDK Application and including the VI with this?
Claire Reid
Message 14 of 17
(3,959 Views)
VDSP is definetely installed. I am writing code with it and communicating with my device through it.
Same thing after re-install.
I am doing exactly what the tutorial has you do, which includes buidling a VDK application.
Message 15 of 17
(3,954 Views)
It seems like there is an issue with the fact that you are/were using your own version of VDSP...
Are you installing the VDSP using the LabVIEW Blackfin installer or using your own installer?  I imagine the installer could place VDSP to a specific location or perform configuration that you may not be doing.
Message 16 of 17
(3,924 Views)
I had the same problem.. I installed everything on another computer and it was working ok..
I assume it's a driver problem, but when i tryed to fix it (drivers), I simply got a bluescreen on windows starting.. (damm vista).. so, I'll install XP Pro and stick with it until my work is done.. :S
try the same thing, on another computer!
best regards
António Veríssimo de Freitas
Universidade de Aveiro Student
Message 17 of 17
(3,894 Views)
