‎08-05-2011 11:23 AM
Good Morning all people,
I want to configure a Blackfin processor BF 527 with LabVIEW Embedded module, and I search the API or function that configure PORTG multiplexer and PORTG function Enable registers, so to configure some pins on peripheral mode. I need some pins to be used in PWM mode.
Can you help me.
THank you.
‎08-06-2011 01:21 PM
Hey,
I have found the application Expert Pin multiplexing plug-in that can configure directly and generate program in c for my configuration, and I have used the inline C and it works. Can I use the buffers to do the same thing.
Thank you for replying me.
‎08-08-2011 12:43 PM
I just want to clarify. The plug in you found was this? And it works fine. So that sounds good. I am a bit confused by your question. Are you trying to see if there is a way to do this in LabVIEW, without using the Expert Pin plug-in you found? How did you plan on using buffers in your application?
‎08-08-2011 01:47 PM
Hey Stephanie,
Yes, the plugin is the one given on the NI website (EE341). I want to do all my program in LabVIEW program, so I want to change the inline C program added in my LabVIEW program with another function that will do the same thing, but all in LabVIEW.
I found the Buffers functions and I would like to use it insteed.
Thank you.
‎08-09-2011 09:52 AM
Which buffer function are you referring to? There are many VIs with the word buffer in them. Is it a specific one you are looking at?
‎08-10-2011 10:55 AM
Hey,
The buffer i want to use is the BF device sequential IO.vi
thank you.
