LabVIEW Embedded
Configuring PORT_MUX and PORTG_FER with LabVIEW
Good Morning all people,
I want to configure a Blackfin processor BF 527 with LabVIEW Embedded module, and I search the API or function that configure PORTG multiplexer and PORTG function Enable registers, so to configure some pins on peripheral mode. I need some pins to be used in PWM mode.
Can you help me.
THank you.
(6,722 Views)
Hey,
I have found the application Expert Pin multiplexing plug-in that can configure directly and generate program in c for my configuration, and I have used the inline C and it works. Can I use the buffers to do the same thing.
Thank you for replying me.
(6,721 Views)
I just want to clarify. The plug in you found was this? And it works fine. So that sounds good. I am a bit confused by your question. Are you trying to see if there is a way to do this in LabVIEW, without using the Expert Pin plug-in you found? How did you plan on using buffers in your application?
Stephanie A.
Americas Marketing Manager
(6,713 Views)
Hey Stephanie,
Yes, the plugin is the one given on the NI website (EE341). I want to do all my program in LabVIEW program, so I want to change the inline C program added in my LabVIEW program with another function that will do the same thing, but all in LabVIEW.
I found the Buffers functions and I would like to use it insteed.
Thank you.
(6,705 Views)
Which buffer function are you referring to? There are many VIs with the word buffer in them. Is it a specific one you are looking at?
Stephanie A.
(6,694 Views)
Hey,
The buffer i want to use is the BF device sequential IO.vi
thank you.
(6,684 Views)
