LabVIEW Embedded
DAQmx emulation in cRIO
Greetings, Is this possible and has anyone ever tried this? I understand that in future versions of cRIO you will be able to directly read/write to C-type modules in LVRT. In the meantime I understand that someone at NIWEEK2007 demonstrated a simple DAQmx emulation. Thanks, Mike Sachs Intelligent Systems www.viScience.com
(6,248 Views)
Hi Mike,
I am not completely sure about the demonstration that you saw. However, I believe the following DevZone [broken link removed] Document has some information on how you can use the Microprocessor SDK to program a cRIO target. Post back letting us know if this was what you were looking for or not. Thank you.
(6,230 Views)
