 A.E.M
			A.E.M
			06-16-2014 05:49 AM
Hi again Brad.
Thanks for your suggestion. Unfortunately, the sync command doesn't change anything. I still get error code 6.
As I see it, we have confirmed that the error is due to the power loss. The reason is, that FAT32 does not supports journaling. So we have a couple of options:
1) Use a journaling file format like EXT3 (or NTFS if that was an option).
2) Monitor which power source is active (officially supported with NI-RIO 14 release) and safely power down the system.
3) If error code 6 happens, then reboot the system (and do a fdisk, which seems to improve the failure rate).
Personally, I like option 2 the most, because we can stick with a file format that Windows and read. Do you have any final recommendations?
 BradM
			BradM
			06-16-2014 07:44 AM
I wholeheartedly agree that detecting the circumstances that lead up to the failure and taking action to avoid it is ideal (well, at least for the current situation).
 NickViz
			NickViz
			09-04-2015 03:18 AM
For somebody that might be interesting in running fsck automatically - here is possible solution explained: https://forums.ni.com/t5/Real-Time-Measurement-and/How-to-run-fsck-vfat-for-USB-stick-during-cRIO-90...
