‎03-23-2009 01:08 AM
Dears,
I dont Understand How Can I Use the Variable Delay to Deploy Variable Delay on a Speedy-33 Kit
‎03-24-2009 12:50 PM
Thank you for posting to the NI Forums!! You should be able to incorporate the Variable Delay.vi into your vi and then build as normal and the functionality of the vi should translate to the build. What type of build are you doing? Are you receiving any specific errors? Thanks!
‎01-04-2011 11:22 PM
can i have the variable delay.vi plz..thanks
‎01-05-2011
01:59 PM
- last edited on
‎03-17-2025
10:59 AM
by
Content Cleaner
Hi mr Joe
The Variable delay.vi is a node in the DSP Module. You will need to purchase the DSP Module to use it.
<Brian Aswege | Applications Engineering | National Instruments>
