LabVIEW Embedded
How can I use the Variable Delay VI (From DSP Module) to Deploy Variable Delay on Speddy-33
Dears,
I dont Understand How Can I Use the Variable Delay to Deploy Variable Delay on a Speedy-33 Kit
(7,678 Views)
Thank you for posting to the NI Forums!! You should be able to incorporate the Variable Delay.vi into your vi and then build as normal and the functionality of the vi should translate to the build. What type of build are you doing? Are you receiving any specific errors? Thanks!
Margaret Barrett
Digital Multimeters and LCR Meters
(7,665 Views)
can i have the variable delay.vi plz..thanks
(7,071 Views)
Hi mr Joe
The Variable delay.vi is a node in the DSP Module. You will need to purchase the DSP Module to use it.
<Brian Aswege | Applications Engineering | National Instruments>
(7,063 Views)
