LabVIEW Embedded
LM3S8962 Build Fail
you've had solved the first problem (by installing labview with supported keil uVision) so my solution was not necessary anymore.
ULINK2 is a debugger, it´s a hardware tool to debug and download firmware to a device.
since you have a ek-lm3s8962 eval board, you can use the build in USB debugger (in settings selecting  luminary eval board as debugger).
Wouter
Wouter.
"LabVIEW for ARM guru and bug destroyer"
Message 11 of 17
(4,784 Views)
Ah ok thanks.
Ill do another reinstall and see if i can resolve the first problem.
So which settings do you mean and where?
In Keil, I couldnt see any 'luminary eval board' debugger.
It had 'Stellaris ICDI', but that didnt seem to work with Labview.
Thanks for your reply!
Message 12 of 17
(4,783 Views)
This error is very common with me, you're correct, the debugger is "Stellaris ICDI", you can automatic select this when create a project in the option "LM3S8962 USB" or manualy by openning the program in the uVision and selecting this tool in the options.
I don't solve completely this problem, sometimes occurs, sometimes not, the best way is click only in "Build" in LabVIEW and after that, download the code using the button in uVision. When the download have problems and the program seems to be crashed, don't try to click in "Cancel", unplug the USB Cable and the program interrupts the download.
Message 13 of 17
(4,774 Views)
Yes it is Stellaris ICDI (it was first ek-lm3s8962 eval board)
but make sure that it is also set under the Utilities tab, select settings, there you can see the attached devices, if it can't see your board there, it won't able to program it with that interface
Wouter.
Message 14 of 17
(4,769 Views)
most labview examples provided for these devices are configured to be debugged with ULINK2
http://www.keil.com/ulink2/
In my personal experience I have worked downloading the usb cable programs without any problem, I have installed LV2012 and LabVIEW Embedded Module for ARM Microcontrollers
http://www.ni.com/white-paper/7066/en
check out this link https://decibel.ni.com/content/docs/DOC-29378
Message 15 of 17
(4,562 Views)
I HAVE THE SAME PROBLEM WITH EKS-LM3S8962USB, SOMEONE COULD SOLVE? ON MY DESKTOP WORK WELL, JUST HAVE PROBLEMS notebbok
Message 16 of 17
(4,515 Views)
Hello Chueco85,
You should post a new thread for your issue as it may not be exactly the same issue. Please also provide a bit more context of your issue. What does the build deployment screen state as the error? Have you tried any troubleshooting steps? Has this worked before and now you're receiving problems? Please make sure to address those questions in your new thread post.
Thanks!
Tim A.
Message 17 of 17
(4,502 Views)
