LabVIEW Embedded
NI board with 4 analog output
I'm looking for the cheapest national instrument with this specifications:
Ethernet communication
1 channel Analog input
1 Digital input
4 channel Analog output
All I found was the Ni sbrio board but the problem that I don't need 80% for its features.
Thank you for your help
(5,785 Views)
Before recommending a particular product, it would be beneficial to understand some the requirements you need for the analog inputs, analog outputs, and digital inputs. What signals are you reading and how fast do you need to sample the signals? Also, what is the general application? Are you going to be logging data or providing control?
Answering the above questions will help us better determine the correct device for your application.
Tannerite
(5,770 Views)
