LabVIEW Embedded
Display the front panel on an embedded screen
I'm doing a serial port test with embedded for arm module. I see there's a function named"Main_FrontPanelInit" in the code generated from my main vi. However I found the funtion was defined as NULL, but the function "Main_InitFPTerms" is solid.
So, 1, I wonder if it is possible to display the front pannel items on the embedded screen? Because it will be a great help in embedded applications, is there any guide or suggestion about that? TKS.
2,   What's the role of the function "Main_InitFPTerms" ? I didn't see it affect the program running.
Thanks a lot.
Message 1 of 1
(5,879 Views)
