LabVIEW Embedded
making 8051or arduino standalone by progamming in labview
hi
I wanted to program an 8051 or an arduino board using labview and make it a standalone system without connecting it to the pc .
is it possible ? if yes, can someone guide me please . I would prefer to do it on the arduino .
hoping for a solution.
(9,391 Views)
It is not possible.
(8,954 Views)
The labview code-generator might be  a solution
(8,947 Views)
Zmobile,do you mean the LabVIEW C Code Generator? If so, check out the price.
The best way to programme a microcontoller is with C code. Use labVIEW on the desktop to provide a user interface, data logging and file storage. Nice combination.
(8,923 Views)
The code generated from C generator is too large for 8051 application. I don't think there's any solution of ur question either.
(8,901 Views)
Hi. You can use 3Dmicro toolkit for standalone application. This is a link http://www.3d-svs.com/3dmicro-toolkit.
(8,895 Views)
The 3Dmicro toolkit http://www.3d-svs.com/3dmicro-toolkit still requires the C Code Generator, which is prohibitively expensive. It also looks like it requires a 32-bit micro.
Would be interesting to see someone write a small application using both something like 3Dmicro toolkit and plain C and compare the development time, debug time, memory usage and application performance. Also, time required to improve performance under both paradimgms.
(8,890 Views)
