 dmoradi
			dmoradi
			01-21-2010 11:43 AM
I was trying to use the timer1 interrupt to see how does it works. I activated the timer1 interrupt from interrupt manager screen and enabled the interrupt including the glibal interrupt enable. then i added a new VI to the project to use it as the interrupt service routine. i addeda global variable and i can modify the global variable from my interrupt VI. so far everything works good. but as soon as i add some simple code to modify the output bits of the MCB2300 (LED0 to LED7) it gives me some error. it builds the project, I can download it to the board but after running it stops the processor and gives some error. If I copy and past the same code from my interrupt VI to the main VI it works without any problem.
any idea why it reacts like this?
why I can not modify any outputs from my interrupt VI?
Besrt regards
 Gmg
			Gmg
			01-21-2010 02:30 PM
01-21-2010 09:25 PM
How can I configure the intrrupt as threaded?
 Gmg
			Gmg
			01-22-2010 09:45 AM
You should be able to just check a box named "Use thread" on the interrupt manager page. Note that this option does add latency.
Here is the doc on the interrupt manager page:
http://zone.ni.com/reference/en-XX/help/372459C-01/lvembdialog/arm_int_mgr_page_db/
