LabVIEW Embedded
Outputs can not be modified from the Interrupt VI !!
I was trying to use the timer1 interrupt to see how does it works. I activated the timer1 interrupt from interrupt manager screen and enabled the interrupt including the glibal interrupt enable. then i added a new VI to the project to use it as the interrupt service routine. i addeda global variable and i can modify the global variable from my interrupt VI. so far everything works good. but as soon as i add some simple code to modify the output bits of the MCB2300 (LED0 to LED7) it gives me some error. it builds the project, I can download it to the board but after running it stops the processor and gives some error. If I copy and past the same code from my interrupt VI to the main VI it works without any problem.
any idea why it reacts like this?
why I can not modify any outputs from my interrupt VI?
Besrt regards
(6,381 Views)
The RTOS does not like it if you allocate anything in an interrupt function.  You can either move this process into the main thread by polling a global that is set in the interrupt, or you can set the interrupt to be "threaded" (this setting allows you to do anything you would in a normal VI).
(6,376 Views)
How can I configure the intrrupt as threaded?
(6,365 Views)
You should be able to just check a box named "Use thread" on the interrupt manager page.  Note that this option does add latency.
Here is the doc on the interrupt manager page:
http://zone.ni.com/reference/en-XX/help/372459C-01/lvembdialog/arm_int_mgr_page_db/
(6,360 Views)
