LabVIEW Embedded
Problems when trying to connect over TCP/IP with DHCP
Hello everybody,
I have problems to get a TCP/IP connection to my Blackfin board.
There is an error message, see in the attached files.
I have also Problems with the UART Interface can't run it with the Code Examples!
Best Regards,
Johannes
(7,656 Views)
Johannes,
The Blackfin lwip stack expects a DHCP server to assign it an IP, you cannot just connect a crossover cable between your computer and the EZKIT (unless your computer happens to be running a DHCP server). Connect your computer and the EZKIT and your computer to a router/switch so that the DHCP server on it can assign IPs to both. Also, you appear to be using the code from the example called Print EZKIT IP Address.vi. I recommend putting this code into a while loop with a wait.
Message Edited by Michael P on 07-27-2006 10:57 AM
Michael P
(7,650 Views)
The has already connection worked (with ping test) with the Visual DSP 4.0++ stdio from analog Devices and their Demo Project.
So i thought that the connection must work with Lab VIEW too.....
But I try it like you described.
Thanks.
(7,646 Views)
