LabVIEW Embedded
Real FFT.vi
Hello again,
I was trying to use Real FTT.vi in embeded Project on LPC2294 and ecos but during compilation I get following error:
Real_FFT.c:281: error: invalid storage class for function 'cln_wrapper_1E8'
It’s the same also for another functions form ‘Analyze’. What is wrong here??
Marcin
(8,229 Views)
Hi Marcin,
The compiler you are using probably doesn't like the way the cIn_wrapper_1E8 is being initialized. To work around this, open the block diagram for the signal analysis VIs you are using (e.g., Real FFT.vi) and double-click on the Call Library Function Node. Select "Run In UI Thread" instead of "Reentrant". This will effect the way C code is generated and likely solve the problem for you.
Michael P
(8,224 Views)
Michael,
For compilation it did help but now I have different, linker errors like:
            libad.a(ReNIFFTH.o): Relocations in generic ELF (EM: 20)
Marcin
(8,220 Views)
Marcin,
You will need to build the analysis libraries for the target so they can be linked in. Refer to the Embedded Porting Guide for instructions on building the analysis libraries.
Michael P
(8,216 Views)
