LabVIEW Embedded
Showing results forĀ
Search instead forĀ
Did you mean:Ā
SPI Port examples
Hi, I  have a ADSP-BF537 EZ-KIT Lite and I want program a tranceivers (CC1020 from Chipcon) using the SPI Port. I was looking for some example of SPI port but I don't find nothing about the subject.  I am trying to learn by myself but I have several question, for example, The BF device Initialize Buffer VI, I don't understand about buffers parameter setting. Is this buffer  similar to data receive and transmit buffer of processor? Please help me because I am lost in the space......!Smiley Sad
(10,381 Views)
The AD7476A uses SPI, and I have attached some VIs that can be used to test this driver. Reference this [link removed; article no longer available] KnowledgeBase article for more information. Hopefully this will help get you started. I recommend that you use Analog Devices' System Services Documentation as a reference.
Michael P
(10,376 Views)
Do you need bi-directional SPI?  We have some fixes associated with it if you need it.
-erik
(10,334 Views)
can someone look at michael's code please?
I can't get dataready to go TRUE, I think the buffer doesn't get full and don't call de callback.vi, why?
thanks in advance
António Veríssimo de Freitas
Universidade de Aveiro Student
(8,294 Views)
I am on and off working of a SPI driver for the AD7476A on the BF548.  The first thing you want to do is verify that the clock is working by monitoring it with a scope when you perform a SPI transaction.  If you don't see a clock, then you have the wrong port selected.  Also, check the MOSI or MISO is setup properly in the code (sorry for the lack of detail, I am going off the top of my head), you should be setup MISO (Master Input Slave Output).
After that, there are a bunch of parameters that need to be verified to match your situation.  I would put up an example of my driver, but it is a work in process.  I can do three quierries, then it crashes.  So I am in the stage of verifying all the setup parameters.  Also, there is a decent explanation of each parameter in the help files!
Hope this helps...
Joe
(8,284 Views)
Hi:
The I/O Analog Read (AD7476) from the Blackfin Pallete works great..
I'm going to use that as a base for my work, my question now is, I want to get the buffer full (imagine 1024 samples) and then call a VI that process all the data..
Do I use the AD7476A open callback VI ?
Best regards
(8,259 Views)
Hi, Michael P.
You code works fine, except for the sub-buffers..
One question, I need to use several ADC's 7476A... how do i use it?
I know the lines are shared (SCLK, MISO and MOSI) but how do I change between ADC's?
I just use digital ouputs to change CS, or is there other way to do it? I know there is a SPI vi that has an input as the port number, is this the better way?
(8,076 Views)
