LabVIEW Embedded
Save 0-n on SD Card
Hello 🙂
I'm trying to use LabVIEW embedded for ARM on LM3S8962 and I would like to save the numbers 0-n on the SD Card by pushing the Select Button. At the moment only the Number, that is shown on the Display is saved. Fo example: "5" is shown on the Display, I push the Select Button and only "5" is saved. But I would like to save "0 1 2 3 4 5".
Can somebody here help me??
(7,481 Views)
Accepted by Nea
Hello Nea,
I guess there is a while loop (or a for loop) around the code that you posted?
The Problem here is, that you only save the value of the current iteration when you press the select button.
To save the old values, you will need another for loop that starts when you press the select button and writes the desired values with every iteration.
I hope following screenshot will help you solve your problem:
(7,456 Views)
Perfect! Thank you Smiley Happy
(7,439 Views)
You're welcome 😃
-- Lam
(7,430 Views)
