LabVIEW Embedded
TCP/IP connection between two ARM boards MCB 2300
Helo,
Here are my answers:
1/ I reduced my VIs to one loop and without variables. I will send the whole project to your e-mail.
2/ I filled in in builds DNS addresses and in run mode I didn't noticed any changes.
Here are results of preformed tests:
a/ Connection between ARM-Client and PC-Server: WORKING
b/ Connection between ARM-Server and PC-Client: WORKING
c/ Connection between ARM-Server and ARM-Client: NOT WORKING (they estabilsh connection but there is no data transfer - I think that the problem is at first block/function TCPwrite/read)
I hope that this was helpful for finding solution.
Thanks & regards
Janez Sluga
Message 11 of 12
(3,354 Views)
Hi
Thank you for your answers. I have contacted our embedded specialists and presented your problem. I will come back to you as soon as I have an answer. In the meantime I can advice only trying to set all timeouts to "-1" so that we can rule-out the possibility of it being to short.
Maciej Antonik
National Instruments Poland
Message 12 of 12
(3,338 Views)
