LabVIEW Embedded
Using Speedy-33 Daughter Card
I would like to use the speedy daughter card in order to use multiple Analog inputs. However, I like to know if there is any instructions on how to use this card. Any helpful advice would be appreciated. Thank you.
(6,482 Views)
Follow this link to a KnowledgeBase article that contains useful information regarding the SPEEDY-33 Robotics Daughter Module. It has a link to the SPEEDY-33 User Manual (section 2-9 discusses the daughter modules). You might also take a look at the Accessories Manual for the SPEEDY-33 as well.
Was there any specific information that you were looking for?
CHeers,
Emilie K
(6,471 Views)
