LabVIEW Embedded
memory storage
Using LV Embedded 8.5 and VDSP 5.0 is there a way to access non-volatile memory on the Blackfin EZ-Kit for storing variables for use on initial power-up? I assume it would be VDSP that would control this through the flash programming operation, but I don't see how to do this yet.
Message Edited by Macbeth on 01-18-2008 02:20 PM
(6,769 Views)
Howdy,
I didn’t see any way to do this independent of a given VI. Basically, I would set the VI application to be a startup application for the ex kit and make constants in the block diagram. I browsed through the help for the VDSP and nothing jumped out at me.
Charlie M. CLD
(6,676 Views)
