LabVIEW Embedded
how to program lpc2368 of the project in LabVIEW to hex file?
Can I create a hex without keil ?
Message 11 of 16
(4,171 Views)
Try this method to launch uVision:
1.Under LabVIEW, right click on Application and choose build.
2.After build is complete, right click on MCB2300 and choose show Keil uVision.
At this step you should have an uVision project called LabVIEW.
Yann C.
France
Message 12 of 16
(4,157 Views)
Accepted by Sergiv
Hi, YannC
thanks, it helped
Message 13 of 16
(4,146 Views)
Sergiv,
LabVIEW Embedded doesn't have the option of creating the HEX file, this must be done in uVision.
Claire Reid
Message 14 of 16
(4,139 Views)
Where can I find out to what church are pin ports? mean: LED0-LED7, AI0-AI7 and other
Message 15 of 16
(4,134 Views)
Hi Sergiv,
Since this post is related to creating Hex files, I will ask that you create a new post for this Elemental I/O questions. If you have any more questions regarding the Hex file please let us know.
Thanks!
Claire Reid
Message 16 of 16
(4,117 Views)
